Straight Duct over 60" overriding auto length specifications
clomedico
clomedico
Why is my straight duct length which should be 56" changing to 20" long on anything over 60" wide?  see screencap
https://knowledge.autodesk.com/community/screencast/62becd3c-6a20-4d86-a63e-2c0f4387503b
clomedico
It seems to be ducts over 60" wide revert to fitting classifaction
clomedico
Hello Christopher,
if Machine Cut, the Straight Auto-Length can be read from either the Fittings or Straights spec section.
You can change it in the Database > Fittings > Pattern Options > General >>> here set Machine Cut Straights to "Straights".
Sample video:
Fabrication - Machine Cut Straight Auto Length
Please let me know if that helps.
Best regards,
Andrea Mazzoldi
Autodesk Support Team
Autodesk GmbH  | Central Europe
Aidenbachstr. 56 | 81379 München
