Spotty insulation on supply ductwork
For some reason I cannot figure out why the insulation is showing up on some of the ductwork but not all. I've redesigned 4 other floors with the same settings and this one is the only floor showing up this way. Is there something I missed? See attachment.
Check your LT Scale it appears it is set to high for the Line Type you are using.
