Spool Template Changing
bd_blues
bd_blues
This morning all of my spool templates change from a SW ISO view to a top view. When the spool drawing first opens it's a SW View but then changes.
stephen.st.russell
Hello @bd_blues
Thank you for contacting Autodesk Technical Support. My name is Stephen, a Fabrication specialist, and I'll be happy to help you with this issue.
I understand you are experiencing a behavior where the view in your Spooling template has changed from SW ISO view to a top view.
Are you still experiencing this behavior?
In Define & Create Spools (SPOOLDWG) is your "Set View To" selection set to SWO ISO?
See more about Define and Create Spool
