Size annotations, annotating both ends
I'm looking for a way to give a size annotation for both ends of a transition, square to round etc.  Is there a way to do this, or is CTEXT the only way to get this done.  Any help would be appreciated.
dyoung
Using the standard Size annotation, you can either size one end or the other but not both as far as I am aware.
Darren J. Young
http://www.darrenjyoung.com/
https://www.linkedin.com/in/darrenjyoung/
dyoung
Followup....
You can't do both ends directly in the UI. However using Lisp, you can get both but it's a 2 step operation.
(setq Item_Number 1)
(setq Item_Size 2)
(setq Item_Elevation 3)
(setq Item_Alias 4)
(setq Item_Set 5)
(setq Item_Length 6)
(setq Item_Custom 7)
(defun c:addalltxt()
  (setq textSize (getvar "TextSize"))
  (setq textSize (+ textSize (/ textSize 10)))
  (setq obj (entsel))
  (setq ent (car obj))
  (setq pnt (cadr obj))
;;;  (AddTextAtPoint Item_Number ent pnt)
;;;  (setq pnt (list (car pnt) (+ (cadr pnt) TextSize) (caddr pnt)))
  (AddTextAtPoint Item_Size ent pnt)
;;;  (AddTextAtPoint Item_Elevation ent pnt)
;;;  (setq pnt (list (car pnt) (+ (cadr pnt) TextSize TextSize TextSize) (caddr pnt)))
;;;  (AddTextAtPoint Item_Alias ent pnt)
;;;  (AddTextAtPoint Item_Set ent pnt)
;;;  (AddTextAtPoint Item_Length ent pnt)
;;;  (AddTextAtPoint Item_Custom ent pnt "Spool")
  (princ)
The Lisp came from here and I've commented out the sections for other annotation types...
http://www.xtracad.com/forum/index.php?topic=13151.0
Shoutout to Josh Merchant/Midlands Mechanical, the author.
Run the Lisp to tag one end. Then Hold the TAB key while you run the Lisp to tag the other end.
Darren J. Young
Thanks, I'll try this out, as well as check out the link.
