Single Line Detail Level
ben
ben
Once you have piping drawn is it possible to have it display in a single line format (similar to revit detail level: coarse)? This would be handy to make it also look like a regular blueprint. Have attachment #1 (piping1) look more like attachment #2 (piping2).
Revit lives in the land of perfect and doesn't understand what construction is.
DJT171
Not sure why you would want to but...... database>takeoff>CAD settings>Display>Only Show Edge Lines if Pipe Diam >    change it to a rather large number higher than your largest pipe size. apply and exit the rebuildall.
AHepker_HOB
You could also freeze the 2D and 3D pipe layers leaving only the CL layer. This wouldn't show connectors unless you are using a connection object (no-hub band) as a separate entity and on a separate layer controlled by the service.
Check out our blog @ HouseOfBIM.com
ben
Basically sometimes we have to do drawings so someone can get their building permit and 3d isn't necessary, besides if I need to change a size on something it's sometimes easier to just change a label rather than change all the piping.
