setup.map error
setup.map error
Everything I enter or close a project I get an error with the SETUP.MAP, it gives me an "error 256".
In the database folder the SETUP.MAP folder shows 0 KB.
My database is acting all funky, some stuff is correct but others goes to the default database.
How do I fix this?
dyoung
If SETUP.MAP is zero bytes in size, it's somehow got corrupt. You can get it off a backup (if you have one) or just delete it and Fabrication will recreate it. You'll likely have to find which settings it stored and reset them.
Darren J. Young
http://www.darrenjyoung.com/
https://www.linkedin.com/in/darrenjyoung/
