seam cut back
csmfabrobert495AH
Observer
seam cut back
csmfabrobert495AH
Observer
Observer
I'm trying to set up a notch for TDC. the turn over is 2" but it needs 2 5/8" notch to go through the roll former. In the connector dialog the seam cut back doesn't change anything. I can change the turnover to 2 5/8 but the part will be 5/8 too long. same as with other connectors like 1" Tap you have to cut the lock seam back further to allow clearance to bend it or form it.
Set the Turnover to exactly how much material you need for the TDC connection, then add the 5/8" to the Straight column.
