REVIT equipment convert
I have exported a lot of equipment from REVIT to CADmep in the past and am doing my first item using 2018 and when I type "processrun" it is now asking for the ".MAP" file. Did I miss something in the upgrade?
nathan.chapman
That dialogue has been there for a while.  Once its set you wont't have to set it again.  Your older version already has the location to a map file hence not seeing that popup.  To find were you current is, go to the version you don't get this popup and processrun.  The dialogue box should appear and in the bottom left corner hit Read Mapping.  Take note of the location and have the new version point to this.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Thank you, I actually found the file by mistake.
