Report List Missing
regal180
Report List Missing
regal180
When I try to use reports the pull down is grayed out like nothing is there. Just for kicks I tried to make a spool sheet and the reports are missing from it also. I went through the MAP.INI and made sure things are pointing in the right location. Is there another file that drive Reports or tells the software where to look for them? It's like things just aren't looking in the correct location. Thanks
Note: Since 2013, the MAP.INI file does not point to the reports location. It points to the Reports ROOT folder.
If MAP.INI points to here....
C:\MyReports
CADmep will look here....
C:\MyReports\CADmep
CAMduct  will look here....
C:\MyReports\CAMduct
ESTmep will look here...
C:\MyReports\ESTmep
