Report Lines
Report Lines
Is there a way to make lines between each item. We are having problems with guys following the hanger cut lists.  we would like to add a line between each hanger like an excel spreadsheet.
MOatman
It is in the Report Builder.  Pick on a field you have added and then look under the Column tab on the right.  You need to check "Separate Change in Consecutive Data" option.
Add to as many fields as you like to make it consistently show up.
Thank you!
