radius elbows change to rectangular
david.barr1
david.barr1
When I export my square duct run in MEP, all fittings in the .rif file are converted from smooth radius, to square bend.
How do i prevent this?
nathan.chapman
What is being filled is driven by your button mapping in the active. service  You can change the mapping or exclude the square bend itm.  Excluding with prevent it from being used in the fill process.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
david.barr1
thanks for the reply.
Is this happening in MEP or in FAB mep? if i exclude the square bend elbow in FAB mep nothing is created.
I'm new to this process so you will have to bare with me.
You have to make certain that the Radius Elbow is part of the button mapping for the service you are in.
1.  Is the radius Elbow a button on the service?
2.  Does the Radius Elbow have a Button Code on the button?  (Right click the button, & choose button properties)
3.  Is this Button Code in the button mapping for a Bend in this service? (Click on the service hyperlink, choose the second tab from the left "Button Mappings", make sure the Button Code from #2 is in the "Alternate Codes" column for a Bend, if not, add it.  (Note, it may be there, but the button code box is unchecked)...if this is the case, check it.)
