Product list problem CID 3523
johnwbrown573
johnwbrown573
Fabrication CADmep 2017
Item: EMT Elbows 90
CID: 3523
It's showing as a catalog/product listed item.  The icon to view/edit the catalog/product list is grayed out.  I've copied the item, unchecked Certified/Cataloged.  Still cannot edit the product list.
Modifying is necessary because the radii for some of the sizes are incorrect and more sizes are needed.
davidronson
That means it is a Managed fitting and thus has been locked by either Autodesk or Building Data. You will not be able to edit the Product List. You will need to rebuild the fitting. Autodesk has since unlocked all of their Product Lists, but I am not sure if you have BD or Autodesk content. You can find out, in Folders right click on the fitting and go to Owner Information.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
johnwbrown573
It's a BD item.
Thanks for the heads up.
davidronson
You should contact them and report what is wrong.
