Processrun command
Processrun command
I have a fresh install of Cad 2016 and Fab Cadmep and for some reason every time i type processrun it initiates the command and hangs autocad. Has anyone ever come across this?
davidronson
This is going to sound strange but do you have a cell phone plugged into your computer? If so, unplug it. This is something I have seen on other forums.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
jonathan_moreno
To assist you with this request would you please be able to provide the following to further investigate the behavior?
- A Screencast video (or a video from some other screen recording utility) showing the steps you are going through.
Jonathan M.
Technical Support Specialist
