Problem with area Value
Hi There,
I have a problem when entering straight duct (GI) for ex: 1000x1000, 1220 length, ideally should give 4.8 Sqm, but I am getting only 4.08. When i ran couple of example i found that CAMDuct is calculating 200mm less in length, ie; when my auto length is 1220, but it is only taking 1020mm. Anyone had similar problem.
When I add additional item with short length (for ex: 500mm) with the same duct size, i still get the same area.
I have attached the a screenshot...
Any help will be highly appreciated.
nathan.chapman
What is your report area Qty. set to.  Change it to "total Item (Extn).Capture.PNG
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
