Problem when importing the file from Revit into CADmep
I need help for the exporter of Revit software to CADmep.
When I selected my elements to convert them to a. rif file (Run of Items), CADmep asked me for a .map file (Mapping File). How do I create this file? If yes, comment? Thank you in advance !!
Accepted solutions (4)
MOatman
See attached.  The file is usually stored in your config folder.
supportrefsa
Thank you very much is it possible to tell me where this file is located ?
Good day, take care of yourself ! :beaming_face_with_smiling_eyes:
MOatman
They are located where your configuration folder is stored.
You can look for a program on your computer named "Edit Configuration" and it will show you where your configurations are or see below.
Example:
C:\Users\Public\Documents\Autodesk\Fabrication 2020\Imperial Content\V3.06
Thank you !
