Preparation of fittings to a specific standard.
jedrzej_fiszerMMJKW
jedrzej_fiszerMMJKW
Hi.
I am trying to prepare a DIN 11850 compliant pipeline for Revit.
My first question, is it possible somewhere to download (buy) .ITM files compatible with this standard that will work in Revit? Unfortunately I couldn't find this anywhere, so I started looking for another solution.
I downloaded CADmep and made a copy of the ready-made pipeline standard found in Fabrication Metric Convent V2.3. I started to modify the ready-made standard for DIN 11850 and here I failed.
I started with a pipe, prepared a table and rewrote the values corresponding to the size.
Unfortunately, this dimension given in the table in no way coincides with the dimension on the drawn pipeline.
Where do you enter the data for the dimension?
Preceding my next question, where do I find the place to enter the data for modifying elbows, tees, etc.?
Thank you for all your replies,
JF.
Replies (0)
