Post processor
Post processor
Is CAMduct has post processor to the following cutters:
Plasma Eurocut 3001.15p
Laser FiberCut II ( CutTech LC2512) ?
thanks for replies
That particular machine doesn't sounds familiar but that doesn't mean there isn't a post for another machine/controller that will work.
Note, in 2016, you can now create a custom post allowing you to setup a machine without a specific post processor.
jarios
Hi darren
Do you have any literature about creating postprocessors in camduct 2016?
LanceTSM
If you know the controller used on each machine you can check if it is currently supported via this link.
https://knowledge.autodesk.com/support/fabrication-products/getting-started/caas/CloudHelp/cloudhelp...
Is there some post builder or some other way how to create your own custom post? Or how to customize one of the preset posts?
I mean to create or edit the VPLs?
thx
LanceTSM
Yes, from Version 2016 onwards there is the facility to add a "Custom NC Machine" and specify the required codes to match your machine.
See link to Help file article below:
http://help.autodesk.com/view/FABRICATION/2018/ENU/?guid=GUID-9C0A1ACA-41AE-41BB-8746-6C0AACE17AC9
