Pipework materials change
Want to change the piping from Tyler to Charlotte.
nathan.chapman
You want to change items that are already in a drawing or trying to setup a new service with Charlotte being the default?
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Change items that are already in the drawings. The report is the wrong material manufacture. When I hove over the material. It's correct.
nathan.chapman
The report could be looking at item product material and not item material.  If you just changed the material on the items the product material would not have updated.  You could either change the report to look at item material or use the command Revdesign and then fill with the correct items.
Nathan Chapman
