- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having trouble with the model I’m producing. I have come back to it after saving it yesterday and a some of the fittings have changed and are now drawing at line size (internal diameter) instead of the size they are meant to be (outside diameter). So an 80mm dia 90 degree steel bend is being drawn at 80mm od not at 89mm od like it should be. The straight pipework is fine until you double click on it to edit it then it also changes to 80mm od once you click “ok”. I have spotted that when double clicking on the item to change the parameters that the material spec under the item tab is showing as Carbon Steel Adesk Data v11 but does not have a BS standard affiliated to it (image attached).
When I start a new drawing I don’t have this problem and the pipework and fittings draw at the correct sizes. When I double click on items in this ‘clean’ model the material spec is Carbon Steel Adsk v5 and has a BS 1387 (6.4m) in the next drop down.
The material box is shown as locked so I can’t edit it we have also tried to copy the items into a ‘clean’ model in another AutoCAD but it overrides the correct setting with the ones that don’t work.
Has anyone got any ideas please?
I am using Fabrication CADmep 2016.
