pipe connectors
pipe connectors
When I put in two straight piece of ductwork it puts a connector between them. What does that? I am not using design line. Yes I want them there but need to know how they get there. I thought it was thru button mappings but I do not see the button code for the connector in the list.
coup is the button code assigned to the coupling.
here is my button mapping:
+ Bend = EL1
+ Bend = EL2
+ RedInline = TRANS
+ OffsetReducer = RedInline
+ RedILTee = STRT, TAP, TRANS
+ RedILTee = T
+ Red4Way = X
+ Red4Way = STRT, TAP, TAP
+ RedBend = EL1, TRANS
+ RedBend = EL2, TRANS
+ ShapeChange = TRANS
+ -------------------------------------------- = EXTENDED MAPPINGS -----------------------------------------
+ TAPD = STRT, TAPD, RedInline
+ PSU = STRT, PSU, RedInline
+ RGS = STRT, RGS
Replies (7)
Keith.Brown
Hi VentGuy,
I believe that this question applies to Fabrication CADMEP and not AutoCAD MEP.  You can find the correct forum here.  http://forums.autodesk.com/t5/fabrication-cadmep/bd-p/165
Hey Keith,
You are correct, I posted in the wrong spot! Blame it on old age lol.
Do I post a new question there or can someone move this to there?
I did search the link you sent (Thanks) but still came up empty.
Thanks for your help,
Wayne
Pothman
I moved the post to the Fabrication CADmep forum for you.
Dave Pothier
Thanks Dave
The Connectors are taking over to find an appropriate match. Go to your Database>Fittings>Connectors
I am not so sure it is possible for anyone to truly explain connectors, but here is a very basic example that i've shrowded a ton of caveats from for the sake simplicity. I add that Fabrications sandbox method of connectivity (while difficult to understand) has empowered me to achieve some pretty epic results I would not expect from any other piping/duct software available. Without building an assembly I've been able to design a 5 (unique) object connection capable of a takeoff as cut-in/stretch populate perfectly.
A Duct Object
Connector 1 Name: Duct Flange
Connector 1 Type: Male
Connector 1 Connectivity: FLG
Connector 2 Name: Duct Flange
Connector 2 Type: Male
Connector 2 Connectivity: FLG
If you haven't disabled error messages (edit configuration dialog) trying to put just 2 of these together should give you a connector mismatch. Basically your trying to put a male on a male and in order to "complete" a connectivity chain there would have to be a female connector involved. In comes the gasket.
A Gasket Object
Connector 1 Name: Duct Gasket
Connector 1 Type: Female
Connector 1 Connectivity: FLG (notice it is identical to the male version....... its mate)
Connector 2 Name: Duct Gasket
Connector 2 Type: Female
Connector 2 Connectivity: FLG (notice it is identical to the male version....... its mate)
If just these 2 objects exist in the service you should be able to keep clicking the duct and it will just keep pairing more of them together with a gasket between them. It is a complete connectivity chain both in sex and connectivity names; size is a factor too depending on what your doing.
If i remember right setting the connector type to "None" will alter the rules of engagement and potentially allow the direct paring of a duct to duct without a gasket. May be more involved then that, but I can't recall since I avoid that method like the plague.
Have you solved the problem???
@Anonymous wrote:
