PCF File Export Question
dbrown
Observer
dbrown
Observer
Observer
Hello, I'm trying to get a clean PCF out of CADmep. Below is a excerpt from a test I'm working on. Gaskets and bolt set are coming out as couplings. The description comes out right but the component name and SKEY doesn't. Does anyone know where this can be adjusted in CADmep?
FLANGE
     END-POINT 109.4882 12.5309 -0.0000 6.0000 PL
     END-POINT 105.9882 12.5309 0.0000 6.0000 PL
     SKEY FLWN
     ITEM-CODE 2
     ITEM-DESCRIPTION CS 150# RF WN Flange STD
     FABRICATION-ITEM
     PIPING-SPEC STD
     SPOOL-IDENTIFIER Drawing1-1
     ITEM-ATTRIBUTE0 CID=[2522]
     WEIGHT 26.0000
COUPLING
     END-POINT 105.9257 12.5309 0.0000 6.0000 PL
     SKEY COCP
     ITEM-CODE 3
     ITEM-DESCRIPTION ST-700 150# Ring Gasket x1-16th
     FABRICATION-ITEM
     PIPING-SPEC IPS
     WEIGHT 0.0000
COUPLING
     END-POINT 105.9247 12.5309 0.0000 6.0000 PL
     SKEY COCP
     ITEM-CODE 4
     ITEM-DESCRIPTION 150# Hex Bolt Set ASTM A307 Gr-B
     FABRICATION-ITEM
     PIPING-SPEC IPS
     WEIGHT 0.0000
VALVE
     END-POINT 95.4247 12.5309 0.0000 6.0000 PL
SKEY should be able to be changed from the connector details of the connector the ITM uses if I'm not mistaken (and I could be).
dbrown
Observer
Observer
Hi, thanks. This was put on hold for a while at my company but now trying to resolve again. The connectivity column you speak of is grayed out. Is there a procedure to changing this?
