OSNAP Overrides When Using "Pick Elevation" and Placing Items Manually
ZTR88
ZTR88
When using the "Pick Elevation" command in the design line pallet, fabrication overrides my current osnap settings and uses "Nearest" etc. This same override occurs when placing items manually with the intention to use attacher.
Is there a way to turn off these overrides? We place sleeves and find elevations using the Center and Endpoint snaps and having to turn those snaps back on each time is not at all efficient for us. Any info. would be greatly appreciated. Thanks.
Replies (0)
