Offset Pipe OD from Trapeze not recognizing Material thickness
ArcoMurrayEngineering
So I created a trapeze hanger and when i cut it in the hanger does not take in consideration the true pipe OD from the materials OD field. It only sees the actual pipe size and the pipe is somewhat into the hanger.
For example:
Pipe says it is 2" in Dia, though with material it is 2.375 for Stainless steel.
I added a custom item data field and set it to:
Description: OD
Add: Always
Type: Value
Default: 0
Then I checked the carry over Option in "Item Entry".
So when I go to the properties on the pipe it only shows the smallest OD # and if i switch to a different size the pipe OD does not switch. Also when i place the pipe in the drawing the pipe OD goes blank.
Please help !
Replies (0)
