Nodes showing up on my plot plans as X
RidgewayPlumbing
RidgewayPlumbing
How do I remove nodes from PDF plot plans ?
lindsey.millerJWDVX
Hi @andreleslie ,
It sounds like you're having an issue within your visual settings. You could try turning off the related Design Line layers to hide the nodes. The nodes are a part of the Design Line. If that solution does not work for you would you mind sharing your file so I can directly trouble-shoot the issue from my end?
@lindsey.millerJWDVX
Lindsey Miller
Technical Support Specialist
RidgewayPlumbing
Thanks you that worked
RidgewayPlumbing
Like how I am on the topic of nodes. Within model space sometimes the nodes get extremely large which makes it hard to work around design line.
RidgewayPlumbing
Continuing. So I would like to use the design line in my sheets so i can see my inverts and sizes unless there is another way.
