new Material, for Ductwork
I have created a new Material, for Ductwork (I am using Fabrication CADmep 2020), however I can not seem to make any piece of Duct the new Material. When I double click the piece of Duct and go to the Item tab, only Galvanized is optional. I have created the new material, so that I can alter it in Revit, so if there is a better way let me know, because I want the colors of the material to be exported when I export to Navisworks.
nathan.chapman
Have you checked if a specification is assigned to the item.  If it is, the material will be stuck to whatever the spec is set to.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
I’m not sure of how you could set a material to a specification. I have added a few screen shots. The 1st one is of the material that I created the second is of the dialog box that comes up when you double click it, Galvanized is the only option.
