New drawing, Wrong material on duct
j_feeke
j_feeke
The material aplied to the new duct is not according the specification default.
i.e: default material for the specification is galvanised steel, but it assigns RVS to the new ductwork.
nathan.chapman
Look on the itm's Manufacturing tab.  I would assume a spec with that material is assigned.  You want it set to "Not Set".
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
j_feeke
Thx for your reply. Unfortunately that is not the case. I have checking with Autodesk and they are kind of puzzled also. For now, the solution is to HARD assign an default material, instead of making the specification decide.
MICHAEL.MCMANUSYDGD9
Any idea on what my have occured
nathan.chapman
Does the duct have a catalogue associated with it?  Is it spiral/oval?  For our spiral/oval pipe we have to create a new itm per material because the spec wont drive the correct material unless the itm default is set from the start.
Nathan Chapman
j_feeke
Hi Nathan,
The issue is currently not there anymore.
Thx for your reply.
It's not separating the duct and pipe elevations and now it seems it's changed the spiral duct into mechanical pipe. I can attach the drawing if you like.
Mike
