more objects & objects modification
Is any one keen to help me out in the following three items:
1- can I get any more objects in HVAC components, e.g manual control damper built in a bend or a tee.
2- Is there any way to modify the objects, e.g make one end of a straight duct on an angle.
3- I can't work that out how to get a grille schedule from Fabrication CADmep after I have done the duct work in a building.
I would appreciate if any one could assist.
Matt
davidronson
You can make additional fittings using the "makepat" command. There are many different patterns see the attached pdf.
In regards to the report, if you want your report to be in CAD use the "addreport" command, if you want to print it out in PDF form use the "report" command. There is a large list of print object to choose from, it will look scary at first. Sometimes the best thing to do is to open an existing report and analyze it. Look a every tab.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
Thanks David for the reply,
I tried to do some changes around the straight duct or add something like a manual damper onto it but it isn't apparantly possible or I don't know how to change the parameters to make it work. Do you have any idea?
Thanks for the advice for reports as well.
Matt
