MAJ file's further uses unknown.
pinaki.rajak
pinaki.rajak
We are sometimes providing MAJ file to client to support them in sheet metal fabrication. My question is, how MAJ files are  used to support sheet metal fabrication?
Secondly I am very curious to know, are these MAJ direct reads by cutting machines? if so, what kind of cutting machines reads the MAJ file?
 They contain the "job" or  information of the system. These are the individual parts that need to be fabricated. Generally MAJ is a job file that is brought in to CADmep. This means it contains all the parts of the system along with services they are suppose to be associated with.  They will then be able to create shop drawings and Spools and create reports listing all the parts and materials required.
 Not that I know of, the Fabricator will make sure the MAJ file (which contains all the parts) is corrected to work with their available services & parts. If they are fabricating ductwork, then they will nest (determine how the piece fit on the material they are cutting from) send the information to the CNC machine to cut the parts to make the ductwork.
pinaki.rajak
Thank you for your initial help and answers, However, need to understand MAJ file's work-ability in detail after producing it from CADmep. It will be enough help for me if you kindly refer me to any document or website link for further study.
