LFILL command in 2017.1.0 is not working
MOatman
MOatman
The LFILL command in version 2017.1.0 is not working.  No pipe and fittings are being filled.  The command line just repeats "Select Objects".
No errors are displayed.
davidronson
Command works here. I am on 2017.1 too.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
