LESS DUCT DIALOG BOXES
asherjoh
asherjoh
When I draw rectangle duct, a duct dialog box opens up initially. But all joints after, don't open anymore dialog boxes. I created round snap lock pipe duct. I don't want the duct dialog box to open for every snap lock joint I add. Since this is obviously possible, based on the rectangle duct, is there a setting that addresses this? I hope I explained it well enough. Thank You
rafal.lewandowski
Autodesk Support
Autodesk Support
Hi @asherj_tmi, Thank you for reporting your case. Round ducts have a default value in their options set as Certified. Therefore, the takeoff dialog box does not show up every time. Press the right mouse on the rectangular duct icon, go to the properties, then options and there select the Certified box. After that you will be able to insert channels without any dialog window after each section. Let me know if that helped you?
asherjoh
That works nicely. Thank You
