Latest Updates | New Knowledge Network Articles | Fabrication CADMEP
matthew.d
matthew.d
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Fabrication CADmep?
 Subscribe to receive updates for new Fabrication CADmep Knowledge Network articles.
For more updated solutions, also check out the AutodeskHelp Blog!
2016 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
October 2018
How to display specific annotations on item Labels in CAMduct
Material overwritten when increasing Database Ownership version in Fabrication
How to automatic nest parts along the sheet length in CAMduct
How to set a different Throat Seam for Tee and Bend items in CAMduct
PDF Underlay is not visible after import in ESTmep
Dampers or Access Doors do not fill in with Design Line in Fabrication
Ancillary cost properties missed in Fabrication item reports
How to set a specific orientation for the label Graphical CNC Part View in CAMduct
Items material not applied after importing a job in CAMduct
Missed decoiled Straight labels in CAMduct
The flange of the Tray with Holes CID 862 pattern can not be set to 0 in Fabrication
In-use Service Templates are lost when purging database in CADmep, ESTmep, or CAMduct
Where to find the Fabrication Fundamental Training exercise files
How to optimize the Taper duct parts development in CAMduct
Fabrication CADmep 2018.2 update fails to install
How to configure the width of the Spool Report table in CADmep
How to change the text size of a Spool table in CAMduct
How to slice oversize Bend Cheeks in the same position in CAMduct
September 2018
Specification does not apply expected material in Fabrication
Adding item folders with sub-folders fails in Fabrication 2019
Maximum Sheet Size option for Straight CID 1 is reset in Fabrication
How to export reports as PDF in Fabrication
Fabrication CAMduct does not always slice off the unused remaining sheet after nesting
Where to find scripting documentation for Fabrication products
Prices truncated when importing Costs in Fabrication ESTmep
Electrical Conduit item not available in Fabrication
Splitter Tabs not applied in Fabrication CAMduct
How to automatically quantify Insulation fixing materials in Fabrication
August 2018
Straight duct auto length is overridden by Fittings Specifications length in Fabrication CADmep
How to assign a specific machine to a material in Fabrication CAMduct
Parts are nested on new sheet instead of available ones with enough space in CAMduct
How to generate multiple Spool drawings with Fabrication CADmep
Connector Fold Slits applied on outer part profile in CAMduct
CAMduct crashes when importing DXF file
Unable to configure Straight CID 866 in CAMduct
Seam annotations appear flipped on CAMduct Oversize labels
July 2018
Fabrication Connector List does not show custom Connectors
Fabrication CAMduct does not generate NC file
Quick Takeoff does not show all required fields in Autodesk Fabrication
Double Wall round collars are not cut out nor reported in Autodesk Fabrication CAMduct
Can I assign the same number to similar items in Autodesk Fabrication CADmep
Fabrication CAMduct: CID 51 - Reducer - unequal parts development
Identical fittings do not have the same item number after renumbering in Autodesk Fabrication
Item and Insulation assigned to the same layer in Fabrication CADmep
Fold notches applied on Seams are not cut out in Fabrication CAMduct
How to use two different bend fittings for an offset in Autodesk Fabrication
Duct Board items do not display thickness in the CAMduct 3D preview
Duplicate entries of the same fitting on Fabrication Item Reports
How to export a report with all available Fabrication patterns
Items are not placed on the expected Service layer in Fabrication
October 2017
Patterns CID 1206 and CID 1207 are missed in the Autodesk Fabrication content
September 2017
How to turn off the Insulation in a Service in Autodesk Fabrication
Item Folders “Auto Arrange” is not available or inactive in Autodesk Fabrication
How to apply staggered seams on Segment Bends in Autodesk Fabrication CAMduct
How To filter report data in Autodesk Fabrication
Warning: “Bad INI file load” while starting the Autodesk Fabrication CAMduct DNC downloade
How to print a report for specific items in Autodesk Fabrication Tracker
How to set a different language for a specific Configuration in Autodesk Fabrication
August 2017
Fabrication CADmep 2018: Hanger - Take Off as Cut In not sized per insulation
CADMEP 2017 CID 521 elevation changes
Design Line does not fill-in bend nodes in Autodesk Fabrication
Duct Couplings are not taken off automatically for specific pipe diameters in Autodesk Fabrication
Labour Rate mismatching between Estimating Summary and Cost Breakdown in Autodesk Fabrication ESTmep
July 2017
Unable to set default seams in Autodesk Fabrication
Workflow Revit MEP/Fabrication CADMep without losing calculated values
Size Block values invert their position while changing view in Autodesk Fabrication CADmep
Opus Note Text disappears in Autodesk Fabrication CAMduct
How to display material color on Labels and Worksheets in Autodesk Fabrication
How to add or remove Annotations on graphical report views in Autodesk Fabrication
How to change the seam position of a round Tee in Autodesk Fabrication
June 2017
Error: “Access is denied. (error opening deferred file)” while writing NC file in Autodesk Fabricati...
Fabrication CADmep: hidden lines for insulation do not appear on rectangle duct and double wall oval...
Item Data exported from Autodesk Fabrication does not show all items
Error: “Error 2 - Unable to Open File” while taking off an Item from the Service Palette in Autodesk...
How to create a shortcut to Autodesk Fabrication CADmep
Missed notches on nested parts in Autodesk Fabrication CAMduct
Parts are not nested nor available for nesting in Autodesk Fabrication CAMduct
Vee Notches depth not as expected on nested parts in Autodesk Fabrication CAMduct
How to merge multiple jobs in Autodesk Fabrication CAMduct
May 2017
Box Saddle pattern developments not notched out as expected in Autodesk Fabrication CAMduct
Development parts missed in Autodesk Fabrication CAMduct
How to change the Feed Rate for specific gauges/materials in Autodesk Fabrication CAMduct
How to set a default sheet size for oversize parts in Autodesk Fabrication CAMduct
Items icons not displayed in Autodesk Fabrication CAMduct 2016
Material Selection does not show all available sheet sizes on Oversize parts in Autodesk Fabrication...
Oversize Seam Notches not applied when set to “Default Oversize Notch” in Autodesk Fabrication
Unable to nest items in Autodesk Fabrication CAMduct
Unable to rotate parts while nesting manually in Autodesk Fabrication CAMduct
April 2017
Unable to apply Specifications to a selection of job items in Autodesk Fabrication
CADmep toolbar is not displaying in Fabrication CADmep
Holes on Straight Duct always applied on the bottom face in Autodesk Fabrication
How to change the default geometry colors in Autodesk Fabrication CAMduct
How to add Item information on Nest Prints in Autodesk Fabrication CAMduct
Item Area or Weight not reported as expected in Autodesk Fabrication
Optimizing drawings within CADmep to avoid slow performance
Seam allowance not applied on Oversize Parts in Autodesk Fabrication CAMduct
March 2017
How to configure material depending Nesting Margins in Autodesk Fabrication CAMduct
How to setup Air Turn and Splitter vanes in Autodesk Fabrication
How to mark items information on nested parts in Autodesk Fabrication CAMduct
February 2017
Cost Breakdown or Reports do not show stiffeners in Autodesk Fabrication
January 2017
Error: “Unable to lock the file” message while opening a Job in Autodesk Fabrication  How To edit the CNC path in Autodesk Fabrication CAMduct
Matt DiMichele
