Koolduct or Ductboard thicknesses change
I am starting to use Camduct to cut Koolduct.  I am working with 42mm Koolduct/Ductboard, but the dropdown menu only supports 30mm. How do I change the setting?
Claude
go to data base - manufacturing - materials - then create ur different thicknesses - then when u draw a profile in drop down menu the thicknessess which u have already created would be displayed
Hi Roy,
Thank you for your reply. I already managed that.
Can you please help with the following:
When designing a product in the Camduct library I have to use the internal
dimension of the product. Can I change this so that I can always input the
external dimension and the program will automatically take that in
consideration when it develops the product.
Example: A few of my products have the same external dimensions, but I cut
them from different board thicknesses. If I can input the external
dimensions then I can only choose the board thickness for the specific
product.
Regards
Claude Marais
