Item Mapping using Revit imported .RIF
- Mute
- Permalink
- Report
Hey all, first post on these grounds so thanks in advance to anyone who might help. I have a working workflow for importing Revit 2016 MEP ducts and fittings into CADmep 2016. These are my own families, not those in the Revit Fabrication libraries. I have mapped a single system (call it system 1) complete with button codes and dimension mapping for each fitting type which is a time consuming process. The import runs well and the result is better than I expected. However, I don't seem to be able to re-use this mapping for a new system (call it system 2) and I need to redo all the mappings again. I am a newbie to this software so is there a trick to this?
Cheers, Chris
