issues with CADmep and AutoCAD since change to 2018
AllstarMechanicalGroup
since we changed to the new 2018 versions of CADmep and AutoCAD we run in more and more issues.
- can't copy a layout (only available when CADmep is started freshly)
- my spools don't save automatically anymore to path I write down when I start a new spool
- spool names aren't anymore in the top of the tab (model or layout)
- item numbers are appear, even if numbers are toggled off
- AutoCAD / CADmep freezes sometimes when changing from layout to model
It's might be our set up what causes trouble. I've installed all updates.
Thanks for the help in advance,
Matthias
Replies (0)
