Issues with annotation
Hello again-again,
I am waiting on a computer from our IT to be set up with all the CAD and Revit software that I need. In the mean time, I'm helping my Sheet Metal Manager over his shoulder on his computer. He is having issues with copying and creating an ogee fitting to be added to the library and is having issues with his annotation style. All I can do is watch videos as this laptop doesn't have CAD MEP. I can't play around in CAD and try out the instructions sot I'm having even more difficulty. I have watched the annotation and creating items videos and have been helping him over over his shoulder with all of these issues. The annotation videos do not explain what to do if your settings are set to standard but the text is still so tiny in model space. He wants the dimensions and text in the model space while he is working in model space. We went into the takeoff menu and the settings are set to standard. What am I missing? What do your standard settings look like in the takeoff menu, section by section? Has anyone else run into any of these issues with annotation or creating a new item? Any help is appreciated.
Thanks!
dglus
In the Database settings go to Takeoff> CAD Settings> Annotation. The "Text Style" under each section should match the Text Style you have created with in the annotation tab in the ribbon. I created a company standard that I use in every drawing I create. One thing I found is that the titles have to match exactly ( including punctuation) in order to work correctly. Once you create a standard, you can make changes to the text style with in annotation tab and not the database. Hope this helps.
