Issue with Pipe Size
I"m using a standard specifcation (ADSK IMPERIAL) to create some PVC Drain, Waste, and Vent Pipe. I know that schedule 40 pvc pipe at 3/4" diameter is an available product, but I can't seem to figure out how to change my settings to allow me to use this size pipe. The smallest size available is 1-1/4" diameter. How do I change the settings to allow the smaller pipe?
davidronson
Steve - The Service you are using is based off the Charlotte cataloge which starts at 1-1/4" (see image). If you are able to get 3/4" DWV PVC Sch40 from a different manufacurer you would need to build or have someone build the cataloge for the supplier needed.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
Thanks. I tried changing the service condition to 1/2" and it didn't do anything. Charlotte has 1/2" pipe available in schedule 40 pvc.
http://www.charlottepipe.com/Documents/Specs/Spec_PVC_40_Pressure.pdf
davidronson
Are you doing a Pressure system or Waste system? The Charlotte catalog for Pressure is available under Mechanical.
