Installation problem
I tried to install the Fabrication Camduct 2016 to windows 8 and when the installation finished Camduct didn't show in the programs folder. Just to mention that the computer is 64 bit and the windows 8 is 32 bit. Is it possible that creates a problem in the installation?
Thank you,
Nektarios Arnaoutakis
HI,You couldn't install 64bit program in 32bit system.by the way, camduct 2016 has some problems with nesting.I suggest you should install camduct 2017 and sp2 also,it has fixed that bug in this version.to do that,you must change you system to 64bit from the old one.camduct software only has 64bit version now and late.
