How to change Write NC location
Hi I work for an IT company that supports a client that is using Camduct 2014. The client is upgrading to 2016 in mid March after purcahsing the product over the weekend with the support licence.
I can't seem to change the Write NC location from the default save location from C:/Users/Public/Documents/Autodesk/Fabrication <version>/<Metric or Imperial> Content/<version>/CNC folder to a shared file location as per the clients request. Can someone help with changing the save location or let me know if this is possible.
James
LanceTSM
Run the "Edit Configuration" app found under Autodesk Camduct 2016 in your Start Menu.
On the Program Paths tab double click the entry for CNC or select it and click the "Browse" button.
You can then browse to the desired location for your cnc files and select it.
Jacob_United
Cheers Lance, have been trying to figure that one out for some time now.
If my post answers your question, please click... Just kidding!
