How do you load the 2019 Fabrication CADmep tools?
How do you load the 2019 Fabrication CADmep tools? When I type in “TBAR” nothing happens. I have uninstalled and reinstalled 2019 Fabrication CADmep and still I don’t have the tool bar visible / accessible.
MOatman
Run the TAKEOFF command to load CADMEP.  If that doesn't work then you have to appload the arx file once.
Arx is located here:
C:\Program Files\Autodesk\Fabrication 20xx\CADmep
TAKEOFF command does nothing. I have loaded the .arx file, also with no change.
