Hidden Plot Issues
ZTR88
Hidden Plot Issues
ZTR88
I'm having an issue with fabrication items displaying properly with hidden settings applied. Edges of pipes and fittings disappear. We had this issue in older versions and the HIDEPRECISION variable would fix it, but now that command is obsolete. Any ideas as to what could be causing this? (See attached image)Capture.JPG
Do you have a listed video card?
Is the firmware up to date?
MOatman
I have seen this recently.  Could be related to the distance of the objects from 0,0,0 in the drawing.  A workaround is to shade the viewport (inside) while leaving the actual viewport settings set to hidden.  It should clean it up.
