Hanger not sized per Insulation
rgettlerPHB
rgettlerPHB
Using 2018 Fabrication. When trying to insert a hanger or cut-in a hanger it is not being sized correctly per the insulation thickness. I have in the properties the box checked "adjust support size".
What else could this stop it from being sized correctly?
jonathan_moreno
Hi Russ,
Thank you for your post!
This incident is currently being investigated for a possible cause and resolution.
Please keep us posted and let us know if there are any questions.
Jonathan M.
Technical Support Specialist
