Getting Drainage to report Invert Levels than centrelines
when using the fabrication levels command for drainage it is giving me the centreline level rather than the invert level which is what i need it to show. can anyone help me into how you can change this. thansks
MOatman
In the Main Database Settings look for "Use same settings for round" under Level Text section and make sure it is checked.
If you just want bottom of pipe you need to remove the T.O.D prefix setting.
Your other option is to use level blocks.
