Full Manual Nesting
jcalderonMJMXC
Full Manual Nesting
jcalderonMJMXC
Need full manual nesting that is as simple as click and drag. The auto nesting and the limited options to manually move parts is painfully annoying. I need best material utilization while at the same time having a linear pattern to cut, something that seems to be one or the other with fusion for the most part...yes on occasion it will auto-nest perfectly but its like throwing the dice and hoping for the best. Working for a manufacturing company this is a disaster.  Please fix this
LanceTSM
Are you referring to Fabrication CAMduct nesting or Fusion360?
boliekcubarti2436
For a more intuitive manual nesting with click-and-drag options, you might want to check out NestFab or Cutting Optimization Pro.
boliekcubarti2436
Manual nesting with click and drag would be a game-changer for precise material use and efficient cuts.
LanceTSM
This is already available in CAMDuct.
