FITTINGS STEP UP/ STEP DOWN LABEL IN REVIT
asherjoh
asherjoh
I have tried to change the Fabrication CadMep fittings step up and step down label (Revit) to read TU and TD (top up and top down). But the label continues to read SD and SU. Any suggestions? See attachments. Thank You
MOatman
In your project try looking under manage tab / MEP Settings / Mechanical Settings.  In there you can set annotation options and tolerances.
asherjoh
That worked. Thank You
