Fill between 2 ends not working
cadpiper
cadpiper
My fill between 2 ends command has never worked on my home computer but it works just fine on my office computer.
I keep getting invalid message on home machine.
Is there a setting or something I can do to make it work on home computer?
Thank you,
cadpiper
This is what I get every time I try to fill between 2 ends. See attachment. Thank you!
cadpiper
Got an answer from friend since my Fill between 2 ends tool tab is not working. At command line I have to type in FILL2ENDS ,and it works. The only thing with that is that it doesnt pop a view screen to show different options. Oh well.
Thank you,
cadpiper
Since fill between 2 ends toolbar button is not working I have to type in command line fill2ends to make it work but I'm not seeing the preview dialog  box thats shows my options. How do I make this work? See attached screenshot taken from a friends machine of what I'm not seeing on my machine... Thank you.
jhoward-HOB
F2E is the NEW and DEFAULT version fill 2 ends command that is based entirely on button mappings. If your service isn't setup with button codes and button mappings then it won't return any results.
FILL2ENDS is the OLD version and it has no dependencies on design line. It simply navigates your parts box looking for options.
I've found that you need both. Sometimes one of those commands will fill something the other won't.
