Fabrication plugin in Revit MEP
I am working in Revit MEP and wanted to utilise fabrication parts in modelling. I have question, how do I import .iez databases to existing setting? Do i need additional software upon Revit MEP alone? Is it possible to have flow in fabrication part duct and pipes? Thanks
You need to have Fabrication MEP
nathan.chapman
aloisiarai is correct in that Revit currently has no capabilities other than reading an existing Fabrication Database.  So to import a IEZ you will need the Fabrication CADmep product. Here is a link showing how to import an IEZ file in Fabrication. https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/2...
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
