Fabrication ITM OD and ID dimensions not matching the correct dimension
devin.prosser
devin.prosser
I am currently creating manufacture specific OD and ID for the fabrication parts and when I assign the OD and ID for a size, it is auto sizing to the next size up. For example if I select a 2" piece of pipe, it is placing the the 3" OD and ID specifications to it. I'm not sure if this is happening because the ID is actually larger than 2" even though that what the manufacture spec says, so it auto sizing to the next size up. Is there a quickfix for this or am I just missing something?
craigjonnson
There are varying methods to setting up pipe diameters within CADMep. The ideal way is to set these up in the materials section.
  1. Select Materials
  2. Drop down to a pipe material
  3. Double Click a pipe material
  4. Check the correct dia is associated with your sizes.
