FABRICATION CAMDUCT 2015 ITEM FOLDER NO ANNOTATION
Recentlt my camduct 2015 item take-offs has no annotations. All database settings appear to be set correctly. (database/fitting/pattern switches/views)
All selections are checked.
MAJ. files created using FABRICATION CADMEP 2015 are annotated.
Any one have a solution for this problem?
davedykes
Hi Jojacomo
It could be that the "Annotate" setting has been turned off in the Views.
I have uploaded a Video that you can wahtch at this link: http://autode.sk/1xxNGFF that explains where and what you should look for.
If this resolves the issue please click the "Accept as Solution" button on the borrom Right so I know this has been resolved.
Dave Dykes
Dave,
Have view video, annotation is visible when editing but not when doing a take-off.
See attached zip file.
Also, yesterday did take-off of a CID 1. After entering a size of 31" X 16" by 4" long, machine built a duct 33" X 18" by 4" long. Today take-off seems to be correct.
Joe Jacomo
Design Manager
Lemoine Marine Refrigeration, Inc
Harvey, LA 70058
503-366-0903
davedykes
Hi Joe
There is no attachment on the post, can you try uploading it again.
Dave Dykes
See attached.
Joe Jacomo
Design Manager
Harvey, LA 70058
503-366-0903
davedykes
Hi Joe
I got the files now thanks.
It took me a while to figure out what was going on, but I think I got to the bottom of it.  I have made a short Screencast that explains what I found and how to fix it.
You can view it here:
http://autode.sk/1ChjLXR
Hope this works for you as well.
Dave Dykes
That worked.
Thanks for the help.
Joe Jacomo
Design Manager
Harvey, LA 70058
503-366-0903
