Fabrication Cam
thehighfielder
Observer
Fabrication Cam
thehighfielder
Observer
Observer
When camming screen freezes
Also "specs in" not recognised
You will need to provide a little bit more information.
thehighfielder
Observer
Observer
When I go to cam in the CADmep menu to create a MAJ file, select objects and ok the program seizes upI have to exit the program via windows task managerI am using the program to CADCAM ductworkAlso my specsin facility to use different databases does not work
Thank You
thehighfielder
Observer
Observer
Thank You
Sounds like the File dialog is locking up. We have that a lot as well as some other users. Not sure how to work around it at this point asside from terminating the process and restarting.
