FABRICATION CADMEP DUCT DOWN SYMBOL
asherjoh
asherjoh
I upgraded to 2017 Fabrication CadMep recently. My rectangular duct down will not show hidden lines. I've gone through all the settings, and cannot get the hidden lines to show on rectangle duct only. Anyone else experiencing this? Thank You.Capture3.JPG
pinaki.rajak
Please check the two option below,
1. When you are connecting your elbow with straight pieces, make sure that the small arrow of attacher is showing green to drop it downwards. If it is showing blue that means its going to upward and it will not show hidden untill you close upward face by an end cap or another elbow.
2. Kindly check it once again and if the problem is still there then, probably you have to check LTS of the drawing.
Please check and revert your observations.
Thank you.
